here is an article on the plusnet website I found
Can I use the modem/router I already have?
We strongly advise taking one of the routers we supply, unless you're an experienced Internet user.
When you sign up to Plusnet broadband you can choose to take a wireless router.
If you'd rather use your own, make sure you check it is compatible.
Want to use a router from another broadband provider? Be aware that many providers lock routers to their network so you may not be able to use it.
The following questions should help you decide:
Standard Broadband
- Does your router say ADSL/ADSL2/ADSL2+ in its description? (You may want to search for the model name if you don't have details to hand)
- Have you bought your router from a high street/online retailer?
Fibre Broadband
- Does your router say VDSL2 Fibre in its product description? (You may want to search for the model name if you don't have details to hand)
- Have you bought your router from a reputable high street/online retailer?
If you answered
Yes to both questions, it's likely that your router is compatible with our service. If you answered
No, we'd advise you to take our router to be on the safe side.
Should you find that your router isn't compatible once your broadband service is up and running, call us on 0800 432 0200.
So it it possible to get your own router as long as you choose a suitable model
