Adobe Premiere question
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Lexus Fan Man, May 1, 2002.
  1. Lexus Fan Man
    Lexus Fan Man
    Is there any way of capturing all the clips on a tape (maybe 40) into premiere automatically, like you can do in studio 7. At the moment i am doing a batch capture and have to select and name etc. each clip individually which is taking ages to get the clips into premiere before i can even start editing.
    In studio 7 it automatically captures each clip based on time and date of each recording, giving me all my separate clips in just one long capture from tape.
    Hope this makes sense and someone can help.
  2. Slipperman
    Slipperman
    I don't think premier has automatic scene detection
    Can't you reuse the Studio 7 clips in Premiere?
    If capturing DV there is a program at this site
    http://www.scenalyzer.com
  3. Lexus Fan Man
    Lexus Fan Man
    Studio captures to one large avi file and then has an config file that goes with it to differentiate between scenes, so that would not work. I will have a look scenalyzer,
    cheers.
