Question Adobe CC
Discussion in 'Photography Forums' started by plloydie, Apr 10, 2016.
Tags:
  1. plloydie
    plloydie
    Jul 11, 2007
    1,206
    116
    West Midlands
    +830
    I have just upgraded my Nikon D90 to a Nikon D7200 took some shots went to look at them in LR5.7 and found that it doesn't support the D7200. Upgrade to LR6 was the option, I thought I'd give the Adobe CC subscription a go but it refuses to load. I have got all my windows 7 updates cleaned the registry run malware and every other similar program deleted everything Adobe on my PC but I still get an error 1 message after the Adobe installer is loaded. Before I phone the help line has anyone sorted this problem out?
    The error reads "We've encountered the following issues. Creative cloud desktop failed to install. error 1"
    I have searched error one but to no avail.
  2. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    What have you tried so far - there are a few Adobe threads about the basic error with some recommended things to try ?
    Jim
  3. plloydie
    plloydie
    Jul 11, 2007
    1,206
    116
    West Midlands
    +830
    I went to the official Adobe site and tried what they recommended but to no avail. I googled the question and all seem to point back to the adobe site.
    I have reinstalled LR5.7. without problems. I have read that I can convert the NEF files in VeiwNX-I to TIFF then import them into LR5.7 so I'm going to give that ago a bit later.
  4. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    Presume you tried the "kill of any adobe/acrobat processes first suggestion then?
  5. plloydie
    plloydie
    Jul 11, 2007
    1,206
    116
    West Midlands
    +830
    As far as I can tell I deleted/uninstalled everything Adobe but will have another go.
  6. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    I think that's running background processes and not removing the s/w - so killing off the background acrotray process related to acrobat reader for example
  7. plloydie
    plloydie
    Jul 11, 2007
    1,206
    116
    West Midlands
    +830
    So I am now at a loss. In a conversation with Adobe they want to remotely access my PC to see if they can find any issues. Not too sure about that.
  8. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    Clear out your Pr0n directory first then :D
    If it's definitely Adobe support you're dealing with then I'd be OK with that provided I could see what they were doing at all times and they would get confirmation before deleting/changing anything...
    Jim
  9. plloydie
    plloydie
    Jul 11, 2007
    1,206
    116
    West Midlands
    +830
    I don't fancy anyone having remote access to my PC so i believe I can use the D7200 shots in LR5.7 if I shoot in jpg. If this is the case I'll try that for a while after all I shouldn't rely on LR to alter the WB I should try to get it right when taking the shots.
  10. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    Fair enough- adobe also do a RAW to DNG converter tool that would do the same job
    Adobe - Adobe Camera Raw and DNG Converter : For Windows
    Might be worth running a couple of RAWS through both conversions and see how the file sizes compare - both TIFF and DNG are Lossless formats.
    Jim
  11. tonyk79
    tonyk79
    Feb 24, 2006
    1,311
    63
    +172
    A friend of mine had this issue when going to the new CC version of Photoshop from CS6. He had a "trial" version and his hosts file on his computer was amended and this prevented the new version installing as it couldn't dial home. go to C:\Windows\System32\drivers\etc and then use notepad to open the hosts file. If you have any reference to Adobe in there followed by numbers 127.0 etc.. then remove these, save host file and restart system. You may be able to install then, its worth a shot.
  12. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    "trial" PMSL :devil:
  13. tonyk79
    tonyk79
    Feb 24, 2006
    1,311
    63
    +172
    Lol, best of it was he could actually get the student and teacher edition for £8 a month!
  14. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,232
    +841
    anyone seen light room and photoshop cc cheaper than $7.99 per month
  15. spannersatcx
    spannersatcx
    Apr 8, 2010
    1,116
    116
    +1,534
    I got it during Amazon Black Friday deals for £75 for 12 months.
  16. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    "so no" :D
  17. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,232
    +841
    $7.99 pm works out as £61 for 12 months
    just bit miffed as I bought LR 6 outright £94, unknowing that any updates CC received wouldn't be passed on :(
  18. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    LR6 standalone has been updated though..... ?
  19. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,232
    +841
    only for bug fix's?, don't think it contains the dehaze and panorama without crop updates
  20. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
  21. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,232
    +841
    yeah I grabbed to dehaze work around presets. Havent checked lightroom updates for a month or so now, if lr 6 can now auto correct the distortion so no crop is needed that will be cool.
  22. shotokan101
    shotokan101
    Jun 16, 2009
    74,883
    10
    Glasgow
    +25,093
    Must admit - not sure if it corrects the distortion without cropping or not just know it allows you to merge wit/without crop and a selection of perspective types for the pano option.... I'm running this latest version...
    Lightroom version: 6.5 [ 1067055 ]
  23. 1080 jawbreaker
    1080 jawbreaker
    Nov 30, 2004
    3,232
    +841
    cc allows to fix the top and bottom areas without cropping once the pano is stitched
