Sparky83
I have various floor plans for our building at work, these are PDF format files and I have Acrobat pro to access them and make small changes etc.
What I want to do is add an invisible text box that only becomes visible when you put your mouse pointer over it. So rather than have a cluttered drawing you can just got to the parts you want. Like a distribution board for example, I want to be able to input the circuits etc and then when you hover over it with the mouse it'll display the info in a text box.
I can kind of do this with the add sticky note tab, and the make the icon invisible but you cannot change the size of the icon, only it's shape, star circle etc.
Can what I want to do be done?? If so how do I do it?
Thanks.
Thanks.
