adjusting the refresh rate sony 32fx66 in service menu
Discussion in 'General TV Discussions Forum' started by ady1, Jan 17, 2003.
  1. ady1
    ady1
    basically i'm noticing this phenomenon of smearing and blockiness on analogue tv and digital cable and would like to try 50hz to see if it's better,i noticed most people saying it's not possible to switch between 50 and 100hz on this set,but i was just looking around in the service menu and noticed an option SCANRATE surely this is for adjusting the refresh? it's on 00h by default and it says to enter a sub address but i no idea what it could be,cause after going through the numbers 9+ then goes to A then B etc etc anyone know how to do it?
  2. Gwyn
    Gwyn
    Jan 7, 2003
    64
    Galway, Ireland.
    Hi ady1,
    Only had my FX66 a week, so I'm not sure, but I too saw this setting in the service menu. Looks like it's expecting a hexadecimal code in the range 00h to FFh but I've no idea of any relevant values.
    Like how does 00h relate to the 100Hz setting?
    I'm not sure that scanrate and refresh rate are the same thing anyway, so it might not be what you're looking for....
  3. Squirrel God
    Squirrel God
    ady,
    I would not touch anything if I were you.
    Many people have destroyed their TVs permanently by making adjustments to service menu settings that mess about with those sorts of things.
    If you don't know what something in the service menu does - never change it!
  4. ady1
    ady1
    i'll leave it alone don't wanna bugger the set up.
