Adjusting Pioneer AX5Ai channel levels
Discussion in 'AV Receivers & Amplifiers' started by MJeeves, Nov 30, 2004.
Tags:
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    I’ve already done the auto set-up on the new Pioneer AX5Ai and I’m very happy with the sound and settings. However, I want to raise the volume level of the rear right surround channel by 1db to match the left surround channel. How do I do this without changing the other settings and having to go through the auto set-up again?
    Thanks.
  2. Jon
    Jon
    Hi Mate,
    Sorry i cant be too specific as im not at home with the amp so cant run through it and tell you exactly, but from memory there is a manual settings section, can remember the name sorry, might be expert or something like that. You have a list of the channels and there levels, you can go through the list and change all the settings as you like. Sorry its vague but thats the best i can do from memory.
    Jon
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Thanks Jon. Do you know if doing this interferes with the other settings that were made by the MCACC auto-setup? Thanks again.
  4. Jon
    Jon
    No Worries mate! No if you change the db level for a channel it doesnt alter anything else, you can alter everything seperately if you want to, i didnt bother as the auto setup was fine, although like you i did change one of the rears to be the same as the other one and changed the distance on a couple as well.
    Jon
  5. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Thanks Jon! I'll have a tinker tonight.
    Thanks again. :thumbsup:
  6. Jon
    Jon
    No Probs, good luck mate!!
  7. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Hi Jon,
    Once you've done the MCACC Auto Set-up do you then have to go through the Advanced Set-Up and Auto Pro (Professional Set-Up) as well to get better results or not? Did you?
    Thanks!
  8. Jon
    Jon
    HI Mate,
    I have tinkered with it in the past, but couldnt really notice any improvment so i just leave it to the MCACC now.
    Jon
  9. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Does anyone have any tweaks on how to get "clearer" and more open dialogue? Any adjustments I could make on my Pioneer AX5Ai?
    Thanks.
  10. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Anyone?
  11. recruit
    recruit
    M.J - Have you checked the levels with an SPL Meter i know the Pioneer has Auto setup but the level's might not be 100% correct on the Center channel it might improve it slightly if you can check it with one and adjust levels accordingly.
    John
  12. MJeeves
    MJeeves
    Feb 15, 2001
    4,038
    Crayford
    +224
    Hi. Yes, I've done all that and if anything I have the centre channel slightly higher than the others (only slightly), be still to no avail.
    I'm gonna get a better stand for my centre speaker to "raise it up" a bit and see if that helps.
    Thanks for your suggestion.
