Adjustable stand for my pj
Discussion in 'Projectors, Screens & Video Processors' started by fred123go, Jan 13, 2004.
  1. fred123go
    fred123go
    Sep 16, 2003
    1,044
    39
    Cobham, Surrey
    Hey all,
    I am completing my transformation of my bedroom to a home cinema in the next few weeks, so the only thing left is an adjustable projector mount, such as this one http://www.avland.co.uk/sony/vplhs3/standlrg.jpg .
    I can't drill any more holes, we moving soonish so mum won't allow, so i need a mount to go behind my sofabed which can reach a height of say at least 100-150 cm to projecto over our heads and onto the screen.
    Atm i am using a fairly small coffe table which needs to go in front of the sofa bed and generally gets in the way.
    any help would be much appreciated
    fred
  2. dek1965
    dek1965
    Jan 20, 2003
    389
    Heysham
    +6
    what about trying a speaker stand, they are cheap, adjustable and would be easy to modd
  3. fred123go
    fred123go
    Sep 16, 2003
    1,044
    39
    Cobham, Surrey
    I was thinking that but i can't find big enough stable ones, and where could i find adjustable ones?
    sounds expensive, oh yeah i have very little to spend on it
    fred
  4. HEADRAT
    HEADRAT
    Mar 4, 2002
    223
    Cambridge
    +9
  5. 3804
    3804
    Jan 11, 2004
    2,760
    71
    England
    +79
    use a good camera tripod with removable platform
    all you need really
  6. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    all you need really
    Thats what i did for my AE100. Got a good one from jessops for £30 and its very stable.
    Anim
  7. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    "Nobo LCD/Slide Projector Trolley"
    I went this route. Excellent, really sturdy piece of kit. And a good price as well. Mines going behind seating.
  8. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    any idea how high these Nobo LCD/Slide Projector Trolleys go?
    sounding like the answer to my problems but i'd need it to go at least 40 inches high.
  9. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    Good idea, i think i might try that if my next pj doesnt have lens shift, are they sturdy
  10. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    "any idea how high these Nobo LCD/Slide Projector Trolleys go?
    sounding like the answer to my problems but i'd need it to go at least 40 inches high."
    Just measured it for you. Maximum height of shelf from floor is 46.5 inches.
    They are a solid bit of kit. The shelf can be tilted if this is required. The unit is on castors which have lock mechanism to stop the unit moving
    I was well happy with it at the price to be honest, alot more sturdy than I thought it would be. The staples price is £40 cheaper than I could find it anywhere else as well.
    I will take some pics of it when it is all setup.
  11. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    harrisuk,
    did you purchase it online or in one of their superstores?
    just wondering because the online site says it's for business customers only,of which i am not .
    we do have a staples in my part of the country so wouldn't be too much trouble if i could buy in store.
    cheers
    paul
  12. harrisuk
    harrisuk
    Jan 24, 2003
    5,328
    71
    +58
    Alot of office suppliers are like this (Viking included).
    They cant proactively "Target" retail customers if they quote their price ex vat. But they will sell to anyone basically. I bought online, and next day delivery was included in the price.
    I think on the order form there was a manditory field "Business Name" I just put my name down and it went through fine. You wont have a problem.
  13. paul1672
    paul1672
    Jul 31, 2003
    2,605
    71
    norfolk
    +46
    cheers for the info mate.
    just took a drive up to my local staples only to be told what i expected (only available online).
    so,i've just ordered one,and ,as you said,order went through ok.
    now sitting back and awaiting delivery.
    many thanks for the tip.
    great idea and solved my little problem re:getting a larger screen.
    paul
