Additional sub or upgrade
Discussion in 'Subwoofers' started by Sammy_D, Apr 28, 2005.
  1. Sammy_D
    Sammy_D
    This is my first posting on this forum ! :hiya:
    I bought my kit in Jan05 and am new to this so excuse my ignorance !
    I currently have a MA 360 sub , ported version (mk2) - its good but i want more - i want bass i can feel. Use will be 90% movies & 10% music
    I originally had the MK1 version but spoke to Monitor Audio in Feb and they changed me to a MK2 in Mar05 - its better than the mk1 - only difference is its ported
    Now my dilemma - to get more bass should i
    1) sell the MA360 (How much would i get for it ???) - assuming i get say
    £200 i could add in max £300 - what sub could i get for £500
    2) Or purchase another sub and go with two subs - again max £300
    What would be the best option - help :lease:
    By the way my room size is approx 23ft by 18ft or 7m by 5.5m ( i think !)
  2. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    I would sell and buy a better sub with the money rather than buy something just the same ,i don't think it will give you the bass you want.
  3. Mroizouk
    Mroizouk
    Jan 11, 2005
    333
    London
    I agree with Bob1. I would also choose to upgrade rather than get another sub of similar calibre, as having the 2nd sub won't really change the character of bass you're getting.
  4. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    I agree with Bob. if you've got the physical room for it, think seriously about the sub in Bob's signature which will cost you £400 all in.
  5. bob1
    bob1
    Nov 7, 2002
    4,313
    Sheffield
    +128
    You will get the bass your after with the svs PB10-ISD that i have , you will get bass you can feel no problem depending the the materail listened too of course ,weather you want to put up with the size is another matter as its not small ,saying that it does seem to disapear almost down the side of the tv.
    If you want to know more about svs subs try looking in the svs forum and have a look on the svs web site .
  6. Sammy_D
    Sammy_D
    Thanks for the advice
    I do like the sound of the SVS subs and have been reading the reviews - they sound impressive - they are also in my price range.
    The ONLY problem is that i have to get in the same colour as my existing speakers ie Beech or something very close - The better half insists ! :nono:
    I see the PB10 doesn't come in beech
    Any other suggestions ?
