Adding widescreen flag to recordings made with HS2
Discussion in 'Blu-ray & DVD Players & Recorders' started by rberman, Dec 21, 2003.
  1. rberman
    rberman
    Dec 21, 2003
    125
    +14
    Using a Pansonic HS2 recorder I have recorded programs and films to the hard disk, trimmed them and then archive them to DVD-R. However, when I dub to DVD-R, the widescreen flag that allows my TV to detect it has a widescreen recording is lost. For this reason there is a menu setting which allows me to specify in advance whether I want the resultant dub to be squeezed anamophically (for display on a widescreen TV) or converted to letterbox format (for display on a 4:3 TV).
    As I have a widescreen TV, I always choose the former option. However, I would like to copy some of these DVD-R's using my PC to give to a friend who only has a 4:3 TV.
    Would it just be a case of re-adding the widescreen flag to the recording, so that my friend's DVD player could then output it as letterbox? If so can anyone recommend a reasonably-priced piece of software that would allow me to do that?
    Or, is it not as simple as that?
    Rodney Berman
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    Doesn't work like that, all your recordings are at 4:3, if the original source was widescreen it is recorded squashed unless you letterbox it at the recording stage by adding the black bars top and bottom to the recording.
    Why not play them back in another player and re-record in letterbox.
    THe other option is that most modern 4:3 sets have a 16:9 mode. If this is manually selected the recording will play back as if it was letterboxed originally.
    THere is no way to add the widescreen switch either at time of recording or later using the hs2.
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    The sets that Ken mentions(4:3 but with 16:9 settings) is the only way to watch a squeezed recording on a 4:3 set undistorted.There is no way,currently,to display an anamorphic recording in 4:3 l/box on a 4:3 set.This was discussed on an earlier thread.Older 4:3 sets with 16:9 merely introduce a false l/box effect and do not work with 16:9 recordings,but these should be few and far between these days
