Adding Track Indexes to a Single MP3 File
Discussion in 'Headphones, Earphones & Portable Music' started by GrooveyTunez, Sep 4, 2005.
  1. GrooveyTunez
    GrooveyTunez
    Jun 14, 2005
    157
    16
    Hi Guys,
    Im doubting that this is possible, but thought id ask anyway. I have a 5 hour DJ set mix. I would like to know if its possible to add the tracklisting to the MP3 file some how so that when the track changes my player (Sony NW-HD5) will display it. Obviously at the moment all it displays is the name of the MP3 file. I have the tracklisting available so it wouldnt be difficult to add them, if this is possible. The file in question is encoded in 192kbps.
    Any feedback appreciated.
    TIA,
    Andy
  2. shadowritten
    shadowritten
    Let's see if I understand you correctly:
    You have a single MP3 file that is 5 hours long. It has a name (filename only, or tag?), but you'd like the entire tracklisting WITHIN that file to be displayed on your NW-HD5.
    Short answer: no chance. Maximum number of characters that the HD5 can display in any field is 60 - which is hopelessly limited, IMO!
  3. GrooveyTunez
    GrooveyTunez
    Jun 14, 2005
    157
    16
    Yes but i meant so that it displays a track at a time, no every single track at the same time, so it wouldnt need anywhere near 60 characters. :rolleyes:
  4. shadowritten
    shadowritten
    Think you need a cue sheet for that, which Sony don't support AFAIK ...
  5. KiNeL
    KiNeL
    Aug 18, 2005
    333
    Essex
    +7
    The only way I can think of doing this would be to chop the file into it's composite songs, preferrably using some gapless method (ATRAC ?), and then individually name each one.
    I'm guessing you won't want to do that !
  6. shadowritten
    shadowritten
    If you can re-rip or transcode the whole set into ATRAC, then there's a function in SonicStage that lets you divide tracks, which you can then re-name and individually tag - thus achieving your goal. And as it's ATRAC, I assume these tracks will still play back gaplessly.
    Anyone tried this?
  7. GrooveyTunez
    GrooveyTunez
    Jun 14, 2005
    157
    16
    Thanks for this suggestion guys. Just tried sending the file over as it is and it doesnt like it. I presume its because its 411mb, anyone know what the size limit is for one track?
  8. shadowritten
    shadowritten
    No mention in the manual ...
