Adding soud effeects from CD
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by lenjones, Apr 4, 2002.
  1. lenjones
    lenjones
    I have Studio 7 software and in the editing mode have no problems with adding sound effects from the built in Smart Sound effects but these are limited and I wish to import sound effects from a CD on the computers CD player onto the SOUND EFFECT channel of the video. I have no problem in importing CD music onto the BACKGROUND MUSIC channel but do not wish to use this channel for sound effects.Any advice would be welcome. Regards lenjones
  2. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    There are 2 ways to do this;
    1. There is a built-in facility for incorporating CD tracks onto one of the 2 audio channels. Its in the Audio Tool Box.
    2. A more flexible way is to strip out the required audio track from the CD and save as a .wav file, this can be imported through the Sound Effects Tab and drag-and-dropped onto either of the two sound channels. Software for saving a CD track as a .wav file is often supplied with CD burning software (eg EasyCD)
  3. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
  4. lenjones
    lenjones
    JefUK Thanks for response. As I indicated I can use your first method to put CD contents on to Background Music track but it does not work in getting CD contents onto Sound Effect track. I will try your other suggestions when I return from holiday in about 2 weeks time Regards Len Jones
