Adding power amp to av reciever
Discussion in 'AV Receivers & Amplifiers' started by chedmaster, Jul 17, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i know there are loads of threads about this but my dad has offered me the use of his nytec(h?) power amp which he says will transform my cd listening. It has a pre-amp as well, which in its current setup is never removed.
    The input to the power amp (from the pre-amp) has exactly the same connection as the cd input to the pre-amp. its about 8 pin in a din style plug, whatever you call that. Question is can i use the pre-outs from my cambridge audio directly into this power amp input, using the current cd player lead (2 phono to the din stylie plug) and use the CA to control volume etc.
    Reason i ask is that i dont want to miss any muting circuits etc that the power amp requires.
    thanks for your help, quick replies would be greatly appreciated as i would like to set it up in the morn! :D
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    well, to all the people that are(n't) intrerested, i connected the nytech up with the preamp, and the power amp is blown/not working :(
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Have you checked the fuse? Tried it on its own and so on?
    You should be OK running straight into the power amp section otherwise. :)
  4. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    yep didnt connect it to amp to start with, straight from the arcam, and just got low level buzzing (didnt change with volume). Fuse is fine, all the lights come on which makes me think its blown up :(. We used it in the pub for a music night with arcam/linn saras, which arent easy to drive i dont think!
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    it was the pre amp :) guess i didnt check it properly. it sounds AWESOME. treble/vocals are so refined, although it doesn't kick out as much bass as the azur itself did, but in my dad's eyes however this amp sounds is how the music should sound! :thumbsup:
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Glad it's working, I'll have to come around and see/hear it sometime. :)
  7. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
