Hi all,
Trying to help my brother with a world cup dilemma. His Projector has broken and we are looking for a replacement. (have posted in PJ forum re that issue). However, one thing that we would like to sort out is that his previous setup had the picture from his SKY+ box going to his old projector via a composite cable
On closer inspection, it seems that the installer ran a component cable from his amp to projector, but as his amp only had composite output the installer connected one of the phono connectors at each end (I hope that makes sense) ie, one connected to the amp and one to the projector.
At the Amp end, he fitted 3 phono connectors so that is ready to plug into a component connection. However at the projector end he has only fitted one phono connector. The other 2 wires are just taped up at the end.
I need to know how to fit 2 more phono connectors and where to buy them from. ASAP !!!!
Many thanks in advance.
Is it a phono connector or is it RCA?!
