Adding more speakers...
Discussion in 'Home Cinema Buying & Building' started by nick73650, Nov 20, 2003.
  1. nick73650
    nick73650
    I have a Sony davs 800 system connected with Sony KP44 and want to know if i can add more speakers thru the amp in the DVD player. I was thinking of buying the Sony SAVS500H speakers or another second hand davs 800 just for the speakers and connecting these to the DVD. Only problem is that i don't know if it's possible to connect these second set of speakers in addition to the existing speakers because there are only one set of connections at the rear of the DVD.
    As you can probably guess, i'm fairly new to this so forgive my non-technical description.
    Any help would be greatly appreciated.
    Thanks, Nick.
  2. nick73650
    nick73650
    Hello.........Is there anybody who can help?.....
  3. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    did u want to run the 2nd set in a different room or something?
  4. nick73650
    nick73650
    No, i wanted to add more speakers to the room because it is a largish room and i've found the Davs 800 speakers to be lacking in the power department. Any help will be greatly appreciated. Thanks, Nick.
