Adding changer for a n00b
Discussion in 'Video Streaming Boxes & Services' started by MrGreedy, Nov 7, 2004.
  1. MrGreedy
    MrGreedy
    I will shortly be getting a 1997 Seat Toledo, and would like to add a CD changer on a tight budget. The head unit is a Grundig 5201 RDS model. A previous owner has had a changer installed, and the connector cable runs to the mounting space in the boot. However, I am unsure whether the changer was factory-fitted or added aftermarket with some kind of adapter.
    So, what are my options, and what would you recommend?
    In addition to the procedurals, any recommendations for a basic CD-R/RW compatible box? Would adding MP3 support break the bank?
  2. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,626
    +6,960
    Have a look here.
