Adding Bluetooth streaming from iphone
Discussion in 'Hi-Fi Stereo Systems & Separates' started by turoasaur, Jul 11, 2019.
  1. turoasaur
    turoasaur
    May 5, 2013
    11
    4
    hello!
    Just thinking of adding an affordable but sonically pleasing Bluetooth option to my set up- to allow people to curate sounds from their phones.
    Currently
    Arcam a19
    Musical fidelity v90
    Budget up to 300£
    What do you suggest?
  2. ShanePJ
    ShanePJ
    Well-known Member AVForums Sponsor
    Jun 20, 2006
    2,815
    Unit 5 The Sidings, Bacup, Lancs, OL13 9RW
    +727
    Have a look at either of these from Arcam. I have the rBlink at home which I push through to my DAC and although you can hear a difference from CD to Bluetooth quality, I've been impressed with its performance
  3. BlueWizard
    BlueWizard
    Jun 19, 2007
    22,630
    +4,310
    A Bluetooth Receiver need not cost much money, though, like everything they certainly can.
    Search Amazon for "Bluetooth Receiver" and dozens will come up -
    The Avantree Oasis Plus (£60) has Apt-X and Apt-X-HD, I don't think it gets any better than that -
    https://www.amazon.co.uk/Avantree-B...Oasis-Plus-Supports-aptX-HD-LL/dp/B07BQYYDNJ/
    Also, it is a Transmitter/Receiver, Low Latency, and Long Range plus Bluetooth 4.2.
    Of course there are many others to consider.
    https://audioengineusa.com/shop/adapters/b1-bluetooth-music-receiver/
    Arcam rBlink Bluetooth DAC
    Steve/bluewizard
  4. oldcootstereo
    oldcootstereo
    Apr 28, 2019
    Canada
    +33
    If you are in the Apple environment, why Bluetooth and not Airplay/wifi? Airplay using full AAC should be virtually lossless where Bluetooth is "low loss".
    Bluetooth vs AirPlay for Streaming Music | Audiogurus
    I use iMac/iTunes (until Apple divides/switches it all this fall)> Airplay/Airport> Apple TV3 (still has the optical output)> Yamaha A-S501 optical input. You could just substitute your iPhone for my iMac, and if you don't need/want the optical input at your amp, just use the RCA connect from an Apple TV4 or 4HD.
    I am beginning to use the iTunes feature where you can set volume/EQ for individual songs, to compensate for some recording/editing/mastering/etc , so there are some potential advantages if you're so inclined.
