Adding an internal Blu-Ray writer to a desktop PC - advice welcome
Discussion in 'Computer Components' started by Bert Coules, Jan 10, 2012.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,348
    +163
    I have a Hewlett Packard p6203uk desktop PC: 4GB RAM, Pentium dual-core E5300 @ 2.60GHz, Windows 7 Home Premium. I'm thinking of adding an internal Blu-Ray writer.
    Is there software available (perhaps bundled with a drive?) which allows authoring of Blu-Ray discs from MKV files, including creating decent menu pages and the like?
    Are there any known problems with burning on a PC and then playing back the discs on a standalone Blu-Ray player?
    Any recommendations for particular makes and models of drives would be appreciated.
    Many thanks.
