Adding a speaker switch to a TV
Discussion in 'General TV Discussions Forum' started by sarlacc, Jul 25, 2003.
  1. sarlacc
    sarlacc
    I'm thinking about adding a button to my TV to easily turn off and on my speakers. I was just going to go to Radio Shack and get a switch to install on the side of my TV that cuts the signal to the speakers. Any tips or suggestions?
  2. Davo
    Davo
    Mar 20, 2002
    12
    Turn down the volume?
    :D
  3. wibble
    wibble
    Jul 24, 2003
    35
    worcester UK
    not a good idea. Disconnecting speakers will leave audio drive stage with no load. Could lead to potential problems e.g. over heating on output transistors/IC. Even if that does not happen you will get a current surge when you switch the speakers back into circuit. Could lead to speaker damage as the current surge will manifest it self as a ' whoomp' sound that can be quite loud/too much for speaker voice coil = burnt out speaker/s:eek:
