Adding A second Sky BOX.
Discussion in 'Sky Digital TV Forum' started by martin23, Apr 4, 2005.
  1. martin23
    martin23
    hello
    I just moved house and i they left the mini dish up so i plugged my sky box in and all working fine.
    At my house before i had a second box in my room with the card which i am still paying for every month.
    My question is how do i connect my second box to my main boix without calling sky out todo it, whats the best way of doing this.
    What will i need? Where will i get it? How will i do it?
    Thanks in Advance.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    You will need to replace the existing single LNB with a twin or a quad unit and then run a new cable to the second digibox.
    At the other house were you a multiroom/mirror subscriber (second card for an additional £10 a month) becuase if you were SKY would have supplied and installed a new dish with all the wiring under their moving scheme (£40 last time I looked).
    If not then all the bits you need can be picked up from many online dealers or a local satellite supplier/installer.
    Satcure is as good a place as any to see what is on offer and prices and they also have a range of "ebooks" that will be a good guide to installing sat hardware if you are starting from scratch.
