Adding a powered Sub to Toshiba 36ZP48
Discussion in 'Subwoofers' started by cellplex, Aug 11, 2005.
  1. cellplex
    cellplex
    May 20, 2005
    5
    Hi all, I have a Toshiba 36ZP48 with the built-in Dolby Digital surround sound processor and the TV has external front and rear surround sounds speakers wired up with the supplied 8 ohm 10 W minimum speakers. Is there any way or indeed any audio benefit to somehow wiring a mains powered sub-woofer into this setup? If so, could anyone recommend a sub-woofer around the 200 pound range ideal for this setup.
    Long term I will move to a dedicated receiver and better speakers but I would like to be able to use whatever sub-woofer I add now to the mix later on.
    Many thanks,
    Ian.
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,951
    Manchester, England
    +83
    personally I would think about adding a dedicated receiver first
  3. t-c
    t-c
    Hi...
    I've been looking to improve the sound from this TV but without the expense and inconvenience of buying and using an AV amp and considering the poor setup of my room. I want to use reasonable components with an ultimate view to having a full blown AV system upgarded in stages.
    I replaced the external front speakers with Monitor audio Radius 90's driven directly by the TV.
    I use the TV rear pre-out via a power amp to drive some big rear speakers.
    Finally i have a REL quake sub for better bass. This has an input specifically linked to speaker ouputs - i connect this to the front surrounds. I know this is not ideal but it does sound great and is very tidy! The sub transforms action movies - but be carefull if you have neighbours....
    Now to find out how to replace the internal center speaker with an external one - anybody had any success with this? I'll start a post on the TV forum...
    tc
