Adding a 2channel power amp
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by bob1, Aug 3, 2004.
  1. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Hello i have had a stereo amp connected to my sony 1080 av amp.I found that this improved the sound on stereo even when using the preamp on the sony.Would it worth getting a power amp for the fronts or should i go for a five channel amp or should i just get a better av amp. :confused: :suicide:
  2. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    I would go for a powerful 5 chanel poweramp - I choose the halo a52 but whatever takes your fancey.
    I had a yamy 630 av amp. I then added a stereo amp (arcam A32). I then added a A52 poweramp. This gives me the options of 7 poweramp channels or using the A32 as a premap and running the stereo through the superior poweramp (which I do).
    I hope that helps.
    CaM
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,775
    The Borders
    +3,288
    bob1
    As you've already 'tasted' the potential advantages of separate AV Processing and Amplification I'd continue down that route.
    There are many options out there for single, dual or multi (5 and 7) channel Amplification and equally as many high quality AV Processors - so plenty of options at your disposal.
    Have a look in the Power Buy section of the Forum's - we have a couple of interesting offers on Atlantic Technology and Flying Mole (I'd never heard of them either) kit that may be ideal for you.
    Best regards
    Joe
  5. bob1
    bob1
    Nov 7, 2002
    4,458
    Sheffield
    +131
    Hi thanks for the replies(been away for a few days) ,i was thinking on the lines of a Rotel RB985 mk 2.I have seen these in the second hand market around the £350 ,is that a good price and is it a good amp? I would no doubt add a procceser when i could afford it.
    Thanks Bob1.
