Adding a 2ch poweramp to the 3802
Discussion in 'AV Receivers & Amplifiers' started by Dom H, Jul 26, 2002.
  1. Dom H
    Dom H
    How much would you need to spend to get a big improvement in 2ch audio? Any recommendations?
  2. Lowrider
    Lowrider
    Rotel will be a big improvement... Bryston even bigger, particularly if you have difficult speakers...
  3. dts_boy
    dts_boy
    Nov 26, 2001
    2,647
    Manchester suburbs...
    +188
    what about if you only have satellites? i have m&k s125 LCR and ss150 rears, is it still worth it?
  4. Lowrider
    Lowrider
    I think so, then the Bryston is probably an overkill...
    I find that receivers don´t have much detail, with the Rotel it was a huge difference, for instance a CD of a piano + cello sonata, with the receiver, (and a reasonably powerful one too, Onkyo 787), you could only ear the one soloing, the background was blurred, with the extra power I could ear both very detailed, the same with every disc, plus better bass and treble...
  5. planbeta
    planbeta
    May 20, 2002
    16
    Stourbridge
    How much does the Rotel or Bryston cost?
    Cheers.
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Yes but it will sound so damn cool....
  7. Lowrider
    Lowrider
    I have no idea of the prices over there, check the net, or wait for any more posts...
    Sure Nic, the Brystons are great, but the improvement from the receiver to the Rotel was probably more than when I got the Bryston, except for the Rotel clipping with my difficult speakers at higher volumes...
