Werewolfs
- Joined
- Dec 29, 2012
- Messages
- 1,427
- Reaction score
- 1,445
- Points
- 529
Just a small question in big scheme of things. Dont know if anyone can help but here goes.
I have PC fans fitted to rear of cabinet two which work on manual switches to only use when playing xbox or using amp. Everything works fine but I wanted to add lights so I know I have fans on(should have fitted light up fans at first). I have tried to fit single LEDs today using the live wire only after the switch and before fan as instructed by Maplins but lights will work and not fans. The transformer is 12v and the Led is 12v. Is it that the power is not enough to run fan plus the light or am I getting the wiring wrong. Tried wiring different ways but no joy. Please help.
Thanx in advance Steve
