Added new AMP now getting faults??
Discussion in 'AV Receivers & Amplifiers' started by mattler, Feb 25, 2013.
  1. mattler
    mattler
    Nov 4, 2008
    65
    Just bought and installed my new amp as my old one didn`t support 3D pass through. Straight away noticed that when using disk (any type) as a source I`m getting a occasional flicker and sometimes the image dissapears for a second. This even applies to the PS3 menu screen?? I`ve done the whole process of elimination thing and it would appear the PS3 works perfectly connected direct to the TV HDMI but when the amp is brought into play the faults occur??
    To summarise:
    PS3 direct to TV all ok
    PS3 through amp, display issues occur.
    Amp is brand new
    PLease advise???
  2. jws
    jws
    Jul 19, 2009
    22
    3
    +3
    Is the amp an Onkyo by any chance? If it is try using the front Aux HDMI port (if it has one).
  3. Davek0974
    Davek0974
    Jan 31, 2013
    217
    +20
    Simple, it's new, it's faulty, return it.
  4. mattler
    mattler
    Nov 4, 2008
    65
    Theres a new amp being delivered on Wed but something is telling me that the same issue is going to be there.
    I have no technical explaination why buy just a hunch! Is there some way that a PS3 may need some settings changed to communicate with a 3D pass through enabled amp to work effectively?
  5. mattler
    mattler
    Nov 4, 2008
    65
    Nope its TEAC
  6. jws
    jws
    Jul 19, 2009
    22
    3
    +3
    Anything else on-line about this? I know my Onkyo had a similar problem and when I checked on-line there were a fair number of people noting the HDMI board can sometimes fail with my amp (TX NR 515).
  7. mattler
    mattler
    Nov 4, 2008
    65
    I`ve done plenty of searching today but nothing conclusive?
  8. ChrisGTL
    ChrisGTL
    Aug 6, 2011
    1,498
    Huddersfield, UK
    +357
    disable ps3 deep black setting.
    worked for me when I got my hdmi amp
  9. mattler
    mattler
    Nov 4, 2008
    65
    Did you have similar issues? Also, where is this setting found?
  10. goujam
    goujam
    Sep 25, 2010
    2,233
    3
    63
    Brierley Hill
    +187
    Teac is a re badged onkyo
  11. ChrisGTL
    ChrisGTL
    Aug 6, 2011
    1,498
    Huddersfield, UK
    +357
    yes I had similar problems. can't remember where the setting is exactly, display settings I think near the bottom
  12. mattler
    mattler
    Nov 4, 2008
    65
    What, on the PS3 or TV?? This is getting massively fustrating with the drip fed info!!
  13. goujam
    goujam
    Sep 25, 2010
    2,233
    3
    63
    Brierley Hill
    +187
    Turn off the deep colour setting on the ps3 its in the display settings
  14. mattler
    mattler
    Nov 4, 2008
    65
    OK! found it and it would seem to have worked....so far LOL
  15. goujam
    goujam
    Sep 25, 2010
    2,233
    3
    63
    Brierley Hill
    +187
    Its a common fault the teac amp has several threads related to it but a lot of other amps have the same problem
  16. mattler
    mattler
    Nov 4, 2008
    65
    Just done a quick search and cant find anything related to the same problem??
    Everything still appears to be ok. When you say "fault" do you think if I go through with the exchange which is arranged for tomorrow for another new amp it would sort the problem, or is it common to all TEAC?
  17. goujam
    goujam
    Sep 25, 2010
    2,233
    3
    63
    Brierley Hill
    +187
    Fault is probably the wrong word its more a feature that's not available. As far as I can see its all the teac units that don't support it. I won't hurt to try the exchanged unit out though. You know how to solve it now !
  18. mattler
    mattler
    Nov 4, 2008
    65
    What I will do tomorrow but then argue my case from the supplier that the amp is not compatible with PS3 and try to get them to change to one that is.
  19. goujam
    goujam
    Sep 25, 2010
    2,233
    3
    63
    Brierley Hill
    +187
    You could try but it not that its not compatible it just doesbt make use.of all the functionality of the ps3
  20. dante01
    dante01
    Mar 5, 2009
    45,852
    +10,958
    Deep colour isn't the same thing as deep black. Deep black is within the remit of 8-bit colour depth while deep colour is in reference to bit depths higher than 8.
    Deep Colour is a pipe dream anyway. In order for Deep Colour to work it must be enabled in the player, an intermediary AV receiver, the display and the content on the disc itself must be authored to include the extra billions of colours associated with Deep Colour.
    The video encoded on Blu-rays is limited to 8-bit colour. There's no actual benefit gained from Deep Colour unless they start authoring content with a bit depth greater than 8-bits and there's no such content as yet if ever.
    Maybe it will be something they start implimenting with the nect gen formats set to replace Blu-ray, but you'd need a different type of player to be able to take advantage of such formats.
