added a power amp, and even in stereo mode amp is very hot?
Discussion in 'AV Receivers & Amplifiers' started by chedmaster, Aug 17, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    ive added a power amp to my CA Azur 540R using pre-outs as usual.
    i assumed this would lighten the load on the av amp as it wouldnt have to amplify the L and R speakers, but watching a DVD in stereo (i.e. just L and R) still results in a very hot amp, as if its still amplifying.
    I assumed that with the speakers disconnected, the circuit would be broken so no current would flow (i.e. no heat?). Its as hot as running in stereo prior to adding the power amp. I can't turn the L and R off in the CA's menus, can you in most AV recievers? is that what im missing?
    Surely the processing can't be producing all this heat? :confused:
    any help greatly appreciated :)
  2. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    It will certainly reduce the load on your receiver,but will not stop the redundant amplifier stages using some power,albeit the amount used at idle.
    The other amplifier channels will also still be using power,plus the pre/processor sections,so you what you describe isn't unusual.
    As to turning off amplifier channels within receiver control menus,I'm not aware of any that allow you to do that.
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    thanks alot :thumbsup:
  4. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    +25
    Processors are computers, computer run very HOT... :rolleyes:
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    Good point,as anyone who owns a Dual Processor TAG AV32R will be well aware of.
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,529
    Near London.
    +208
    Also don't forget that the input transformer (part of the units PSU) will also still be running hot. I find that this is probably the hottest part of my Marantz even with it's current feedback design which is a topology renowned for being hot. :)
  7. psflynn
    psflynn
    Nov 10, 2003
    341
    Swindon
    +5
    Chedmaster, what power amp have you bought ??
    Noticeable improvement?
  8. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    its my dad's old nytech bout 20 years old but very very good! vocals are much clearer and more detailed and theres less bass than im used to id say its improved music (in my opinion) by 30% and movies slightly more, the centre channel is liberated and the rears feel more punchy. some technical terms in there :D
    id say its definately worth it up to about half the price of the amp.
