Add power amp to Arcam AVR550
Rasha28
I wanted to add a compatible power amp to my Arcam AVR550. It currently powers Kef R900 for fronts, kef R300s as rears x 4, R600 got centre and and an REL 212se subwoofer. Seems like the fronts can do with a bit more power. Any tips would be appreciated.
Thx
Rasha
StefanBFC
Emotiva or Nord's would be a good place to start looking, depending on you're budget
Rasha28
Any particular model? Budget will be around £1500.
Thx
D
Deleted member 39241
Be aware of gain matching. The Arcam power amps designed to match these receivers have a low input sensitivity of 800mv. Arcam recommend in the manual for the AVR550 to use a power amp with a gain of 31db.
The AVR550 hasn't been measured but the 390 and 850 have, and the results were a bit odd, depending on whether the speakers are set as small or large.
If you want to research that, have a look at the tests on Audio Science Review.
If you want to play it safe, just use a power amp with the necessary 31db gain.
rccarguy2
I'd go for one with high gain older emotiva had 31.
Most are 29.
BlackSpider777
Thx
Rasha
which power amp you eventually bought?
Thanks.
