Adapter Ring For Cyber-shot Dsc-v1
Discussion in 'Photography Forums' started by stormchaser, Aug 17, 2005.
  1. stormchaser
    stormchaser
    Nov 19, 2002
    450
    +10
    hi
    does anyone know where I can find ADAPTER RING FOR CYBER-SHOT DSC-V1?
    many thanks indeed
    cheers
  2. longleyc
    longleyc
    Try the Sony site is the obvious answer. Or Jessops
    Im assuming you want to add a teleconverter/filters etc.
    Normally, these are named as "Step Up or Step Down" converters as often the other lenses/filters are of a different ring diameter, therefore needing to step up or down to match the accessories.
    Tele conversion lens * includes adapter ring
    VCL-DEH17V (1.7x)
    Wide conversion lens *
    VCL-DEH07V (0.7x)
    But I think on this model the adapter fits onto the body rather than the lens as the lens rotracts fully into the body on power off. Probably get some vignetting on the tele lens if its not zoomed right out.
    If you plan to just buy the adapter and find a cheaper third party lens then I think searching some photo sites/ forums might point ya in the right direction. Dunno if thats poss on the V1 though.
  3. stormchaser
    stormchaser
    Nov 19, 2002
    450
    +10
    hi
    sony and jessop sites were no good. :(
  4. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,215
    Weardale
    +57
    have you tried e-bay..? - I got one for my canon g5...
  5. longleyc
    longleyc
