Adapter for overhead DVD required (AD-6874)?
Markbirdy
I have just purchased a car with roof mounted player (Directed Video DV2601).
Here is the wiring diagram (or similar):
It's connected using a 13 pin din connector as I have a loose connection behind the glove box.
I also have what appears to be a loose power connection with black, red and yellow connections:
The DVD unit itself works as I've removed it and plugged it into a separate 12v power supply so it looks as if I need to wire the car up correctly.
Do you have any idea where I might purchase an adaptor like this? I think it's the AD-6874 but I'm sure there are others with the same connections that might do the job? It has to have 13 pin din input from the monitor:
Lite Speed
Hi Mark, did you end up finding an answer to this? Ive come across the same issue, with the same model unit! Did come across a similar plug like the photo, but not sure where to source it...!
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
