Sadly GDPR means we can nolonger offer access to AVForums via the branded app or Tapatalk.
Adapt RCA cam cable to Firewire?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by blackbird, Jul 24, 2005.
  1. blackbird
    blackbird
    I just sent for:
    A Bullet Cam from http://www.smarthome.com/7574.html which has RCA cable
    Web Cam Monitor software from http://www.deskshare.com/wcm.aspx which requires a firewire connection
    And a Firewire card from Dell
    However I’m wondering now if they will be compatible. Can RCA cable from the cam be adapted to a Firewire connection? Or does that defeat the purpose of firewire.
    The cam accessories include: • RCA adapter, Male/male RCA cable, Male/male RCA to 6-pin coupler, RCA/BNC connector
    The Web Cam Monitor software is supposed to detect motion and then record it according to settings
    Thanks for any help.
  2. Roy Mallard
    Roy Mallard
    Do a search under 'Dazzle' and 'Keene' there are analogue video>dv convertors out there, expect to pay around £150-£200, don;t know much else about them, i.e. can they be left on all the time and be triggered by software activiation... anyway you can ask the sales guys that.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    As Roy has suggested, you will need to buy a converter as the bullet cam is analogue and firewire is a digital connection.
    A DV camcorder with AV-in enabled will be able to do the conversion, but many sold in the UK do not have this. Otherwise it is a converter as suggested at £150-£200, another popular make being the Canopus ADVC converters.
    If you just want basic CCTV use then you are probably going to be better off getting a USB webcam at around £20-£30 or an analogue to USB AV card, but then the software you have may not work as you say it requires a firewire input. Therefore a very cheap camcorder may be the best option.
    Mark.
