For Sale ADA Cinema Rhapsody Mach IV-B Superior HT Preamp
Discussion in 'Archived Classifieds' started by NaTT, Dec 22, 2017.
  1. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    A professional grade Cinema processor, that rarely comes up for sale so grab it while you can.
    Mine is the NON-RACK-MOUNT version, although it's been sat on a tray in a rack whilst with me.
    I'm the second owner having bought it from StoneAudio, this item having been returned to them.
    It's got the latest HDMI upgrade, but won't pass 4K video. The sound quality more than makes up for this.
    I've got the PC software to help configure it, but it can be configured with the front panel.
    Comes with original packaging "tastefully" covered in packaging tape.
    Featuring Balanced Audio Outputs
    [​IMG]
    [​IMG]
    For a high resolution product shot, click on an image.
    The Cinema Rhapsody Mach IV-B is ADA's superior home theater controller/preamplifier. It features 8 HDMI inputs, 8 analog audio inputs, 8 digital audio input, and an 8 channel analog bypass input. There are also dual mirror HDMI outputs helping separate the Cinema Rhapsody Mach IV-B from other preamplifiers on the market. While similar in design to the Cinema Rhapsody Mach IV, the "B" version features balanced audio outputs.
    The Cinema Rhapsody Mach IV-B decodes all the latest Dolby TrueHD, DTS-HD Audio Master and Multi-Channel PCM soundtracks found on Blu-ray DVDs. Just as HD video is noticeably better than regular DVD, these high-resolution (lossless) audio formats are dramatically better than regular 5.1 or 7.1 surround sound. You really can hear the difference and will never want to watch or listen to regular DVDs ever again. In a word, the home cinema as experienced on the Cinema Rhapsody Mach IV is fabulous.
    The Cinema Rhapsody also has incredibly unique features that make it the only controller choice for many home theaters. In addition to featuring a simple to read and operate front panel control and its abundance of connection jacks, the Cinema Rhapsody Mach IV-B incorporates two bass crossovers, one in the DSP and one in the analog domain. This makes it possible for the Cinema Rhapsody Mach IV-B to work with full-range speakers, permitting them to play bass information while at the same time summing the bass of full-range channels with channels that are rolled off as well as the LFE (low frequency effects or ".1") channel. The subwoofer (speaker best designed to deliver bass) plays the bass from all channels simultaneously with the other speakers that are capable of delivering bass. With any other preamp, full range speakers would need to "roll-off" (not play bass) so that the subwoofer would play the bass. Not so with the Cinema Rhapsody Mach IV-B. Similar to providing a video loop facility so that one can incorporate the very best video processing, the Cinema Rhapsody makes it possible to incorporate the very best speakers into your system without compromising performance.
    • Dolby TrueHD & DTS HD Master Audio
    • Multi-Channel (192KHz/24 Bit) PCM Audio
    • Full 7.1 EX/ES, THX Ultra 2, Dolby Pro Logic IIx, DTS Neo 6
    • 8 HDMI Inputs with HDMI Equalization Settings per input
    • 2 (Dual) Mirror HDMI Outputs with HDMI Equalization Settings
    • Parametric Multi-Band Equalizer
    • 8 Stereo Analog Audio Inputs
    • 6 Digital Audio Coaxial Inputs
    • 2 TOS-Link Optical Digital Audio Inputs
    • 8 Channel DVD Audio/SACD Input With Bass Filters
    • 8 Composite Video Inputs
    • 8 S-Video Inputs
    • 8 Component Video Inputs
    • Analog And Digital Audio Record Outputs (2nd Zone)
    • 2 Main And 2 Record (2nd Zone) Composite Video Outputs
    • 2 Main Component Video Outputs
    • Rear Panel Ethernet Connection (ADA Net)
    • 2 Programmable Low Voltage Output Triggers
    • 90-260Volts AC 50/60Hz 40 Watts
    • 23 lbs 3.5"H x 19"W x 17.5"D
    Price and currency: £2250
    Delivery: Delivery cost is not included
    Payment method: Cash or bank transfer
    Advertised elsewhere?: Not advertised elsewhere
    Prefer goods collected?: I prefer the goods to be collected
    ______________________________________________________
    This message is automatically inserted in all classifieds forum threads.
    By replying to this thread you agree to abide by the trading rules detailed here.
    Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via private conversation to each other after negotiations are complete and prior to dispatching goods and making payment:
    • Landline telephone number. Make a call to check out the area code and number are correct, too
    • Name and address including postcode
    • Valid e-mail address
    DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
