actual size of viera cabinetstand ?
Discussion in 'Home Cinema Buying & Building' started by pantai, Jan 6, 2005.
  1. pantai
    pantai
    Can some one owning the panasonic 37" or 42" viera with! the matching cabinetstand tell me the exact hight (in cm or inch ) between the bottom of the plasma screen and the glass, between the 2 glasses and between the buttom of the stand and glass? So i know if i can fit my dvd player etc in these 3 spaces.
    Coz i can't see the stand itself in a store nearby. (netherlands)
    Also do you think the panasonic isn't kinda slow when changing channels compaired to Sony ? Does it bother you ?
    thank you for your info,
    Pantai.
  2. RicsterG
    RicsterG
    Dec 31, 2004
    75
    +5
    Hope this is of help. I did some research before ordering mine searching everywhere :)
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Yes it is a little, but not something I would consider to be a problem. As long is it does not take more than a couple of seconds it does not bother me one bit. After all, how quick do you need a channel change to be? :D
  4. harrison99
    harrison99
