Actual physical size of a 42" plasma?
Discussion in 'Plasma TVs Forum' started by RHCP, Aug 28, 2005.
  1. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    What is the actual physical size of a 42" plasma?
    I've read it in the forum before but can't find it now!
  2. Sparky101
    Sparky101
    Nov 17, 2002
    283
    +18
    It depends on the plasma.... Try look at the manufacturer's website for the plasma you're interested in.
  3. bishman
    bishman
    Mar 29, 2001
    4,904
    83
    hertford
    +174
    they all work out differently. Are speakers side or bottom mounted for example? Like sparky says, just look at the manufacturers sites, they usually list sizes of the units.
  4. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    The new hitachi pd6600, but could'nt find a manual!
    I'm just looking for approximate size, cheers :)
  5. Troy Tempest
    Troy Tempest
    Aug 29, 2005
    4
    +3
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    :smashin:
    Good first post!
  7. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
