Question Activity puts recorder to sleep if awake recordings
Discussion in 'Home Cinema Control & Remote Controls' started by RobTi, Sep 2, 2018.
  1. RobTi
    RobTi
    Dec 11, 2003
    2,581
    Hamilton
    +151
    Hi I have an elite, with a watch tv activity using a Humax HDR Fox T2 and it all works as it should except when the humax is recording which means it is already awake so my start activity puts it to sleep and the opposite if I power off, I get around this by going into devices and power toggle it. So I just wondered if anyone had come across anything like this and can help ?
  2. logiciel
    logiciel
    Feb 2, 2008
    52,999
    UK
    +5,729
    If you have two activities with the same device then turning the second one on won't affect the first.
  3. RobTi
    RobTi
    Dec 11, 2003
    2,581
    Hamilton
    +151
    Hi I come in and the humax is recording I start my watch tv activity and this puts the humax to sleep
  4. logiciel
    logiciel
    Feb 2, 2008
    52,999
    UK
    +5,729
    It won't if you're already in an activity, which you should be.
  5. RobTi
    RobTi
    Dec 11, 2003
    2,581
    Hamilton
    +151
    Sorry it does, the box switches on for recordings, so there’s noway the harmony knows this. I have deleted the activity and devices for this and reinstalled but the same result the harmony doesn’t know which state the humax is in so power toggles what it remembers as the last one used but in the meantime the humax has switched on to record
  6. logiciel
    logiciel
    Feb 2, 2008
    52,999
    UK
    +5,729
    Machines normally record even when they're on standby.
    Are you sure there isn't an option for this?
  7. RobTi
    RobTi
    Dec 11, 2003
    2,581
    Hamilton
    +151
    Thanks will check for this
  8. RobTi
    RobTi
    Dec 11, 2003
    2,581
    Hamilton
    +151
    Update it turns out that as I have a custom firmware the box wakes fully up while recording to decrypt and cut the add breaks, the standard box doesn’t, so looks like I will live with it as it’s just a minor annoyance, thanks to Logi for helping out
