Active sub longshot!
Discussion in 'Home Cinema Buying & Building' started by themanpuff, Sep 7, 2007.
  1. themanpuff
    themanpuff
    Sep 7, 2007
    Hello - I'm new here, wondered if anyone could help. I've just got a (very cheap) JVC SP-THA85 speaker system as the dvd part of the system was knakered. I am trying to hook up to my AV amp (PIONEER VSX-516) - the surround speakers are no problem, but the sub is designed as part of the "integrated package" and so contains an amp for all the other speakers. So I was just wondering if anyone knows if I can use the "system" type active sub as a standard sub with conventional amp.
    That was a long old explanation! Would be grateful if anyone has any ideas!!
  2. dbs2
    dbs2
    Jun 28, 2006
    1,596
    Sunny Norfolk - uk
    +196
    Hi.... :hiya:
    Sorry, no i havn't got a clue...... try posting this in the 'Audio Components Section' you are bound to have more luck there...... :)
  3. inzaman
    inzaman
    Dec 16, 2002
    8,013
    Derby
    +1,076
    This is not diy related so i will try it in all in ones for you.
  4. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    the answer is pretty much NO.
    you could buy a half decent sub for about £50-£60.
