Active Speaker/Decoder Systems
Discussion in 'Home Cinema Buying & Building' started by davidwatsonok, Sep 23, 2003.
  1. davidwatsonok
    davidwatsonok
    Jun 24, 2003
    1,311
    Yorkshire
    +136
    I'm thinking of buying a combo DVD/VHS unit for the bedroom and would appreciate some advise on a suitable active speaker set-up to get DD/DTS.
    I 1st looked at the LG DV2000 which seemed ideal having DVD, VHS and all the speakers in 1 neat package, but I can't find one with multiregion.
    The best solution I've found is the Panasonic NV-VHD1BS with multiregion and S-VHS playback, but I'll have to add speakers and processing to that. Can anyone recommend a budget set-up ?
    All replies greatly appreciated.
  2. willbrady
    willbrady
    This reply may be a little late, but I have just bought the dv2000 and there is a patch you can download for it to make it multi region - works a treat.
    Let me know if you bought it and I'll sort out the patch.
    Best
    Will
