Active Powered In-Ceiling Speakers for Squeezebox.
Discussion in 'Music Streamers' started by JayGannon, Jan 30, 2009.
  1. JayGannon
    JayGannon
    Jan 30, 2009
    Howdy,
    I am looking for some good budget in-ceiling (or wall) active powered speakers for 4 rooms in a new build. Any reccomendations?
    Thanks in advance.
  2. RossDublin
    RossDublin
    Apr 13, 2006
    49
    I looked in to this a bit before doing up my house about a year and a half ago and I couldn't find any reasonable active powered in-ceiling speakers worth considering.
    I had three areas (one living space and two bathrooms) that I wanted to put ceiling speakers in.
    In the end I went for non-powered speakers and I have yet to connect an amp up to power the bathroom ones - albeit this is partly due to other commitments. I do plan on putting an amp on them soon though and using the Squeezebox Duet controller to control my music from the bath - sweet!
    If you are looking at bathroom in-ceiling speakers i went for B&W single stero speakers - so you only need to put up the one speaker and it will play both channels.
    Sorry I can't really answer your question properly!
    Ross
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,724
    The Borders
    +3,513
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    There are a few options as always depedns on budget and you'll probably find it cheaper to fit a small multi-room system like:Nuvo Simplese with Speakers (UK) Or go sonos instead of squeezebox, the biggest issue is feeding mains power to the speaker and controlling it. Genelec Genelec Oy - Genelec AIC25 do some decent in ceiling actives as do POLK LC80i-IP Product Page : Superior Sound and Internet Addressability From Speakers You Can Barely See : Polk Audio but both are pricey. Cheape roptions are ABUS actives from Opus AMR650 active in-ceiling speaker / Opus 500 / Opus systems / Opus Technologies but can be rather weedy.
