Activating Prog Scan on Burnout 2 (PS2)
Kazuya Mishima
I thought you just had to select 60 Hz at the start - i didn't realise there was a code for it.....
bash
hold down /_\ & X whilst it loads up, its a hidden option mate ;)
bash
Hold them down after you see 'playstation 2' flash on the screen.
Kazuya Mishima
When I choose 60 Hz I see a visible improvement over 50 Hz (viewed on a 42" Panasonic plasma). Would this suffice?
O
olaiho
I confirm: no ProgScan in PS2 Burnout 2 PAL. Too bad, really... Otherwise the game is one of the best demos for home theatre gaming.
BR,
Olaiho
bash
Lol, I have Us version on my tosh strata, looks lurvly too ;)
Kazuya Mishima
Originally posted by RL123
Yes it can but it's software-dependant. Only a few games support it atm
Tekken 4 is one.
bash
US Burnout 2 is another :D
The getaway is the first PAL Prog Scan PS2 game I believe, I cant think of any others.
flangemonkey
Yep, NONE of the Burnout series in PAL territories support progressive scan. For NTSC versions, you still have to hold triangle+X on bootup to enable it.
The Criterion-developed Black conversely DOES support progressive scan for the PAL release (using the same button-holding trick) - and very lovely looking it is too...
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
