I've just purchased one of these to hopefully integrate with myHTPC, only problem is i can't seem to find a driver since i need to write a little app to change my cable box to the desired channel.
Does anyone know of a DLL/ocx control or similar which i can use from within Visual Basic to send out the desired codes?
Failing that does anyone know of a simple command driven app which i can use to do something similar?
Colin.
Colin.
