Action Switches
Discussion in 'TAG McLaren Audio Owners' Forum' started by Yps, Jul 14, 2004.
  1. Yps
    Yps
    Jun 10, 2004
    5
    Hi!
    I have a AV32REX with action switches. I will try to build a own electrical curtain to my window and control it with actionswitches.
    I have have looked into the menus of the AV32R, I think it is only possible to trigger the actionswitches when I change input from CD/DVD/TUNER ..... and also standby (to control an amp)
    I use my DVD also as CD.
    Is it possible to have one button on the remote to trigger the action switches? Or do I need to add a new player (CD) that I will use when I only listen to music ?
    I hope you understand my question.
    Best Regards, Magnus.
  2. PhilB1234
    PhilB1234
    Hi Magnus,
    Do you have a learning remote such as a Philips Pronto or Marantz RC5000?
    If so there are RC5 codes available for direct control of the action switches, for example:
    Switch A On: 19 10.
    Switch A Off: 19 11.
  3. Yps
    Yps
    Jun 10, 2004
    5
    Thanks, I will try a PocketPC as remote control.
    /Magnus
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    best of luck :D
    With respect (so I don't suffer the wrath of any iPaq fans) I think you will find the latest Pronto's a far better bet for controlling your kit and many many files already exist for you to alter to your hearts content. I was very disapointed in the general ability and IR range of my iPaq when I tried it and the fmaily always had the hump when it was in my pocket at work when they wanted to use the thing........A dedicated remote interface is the right way to go.
  5. TaxHamster
    TaxHamster
    Jul 8, 2004
    39
    11
    +11
    Hi Magnus,
    Here's a complete list if the direct switch codes for the AV32REX:
    Switch A on: 19 10
    Switch A off: 19 11
    Switch B on: 19 40
    Switch B off: 19 41
    Switch C on: 19 42
    Switch C off: 19 47
    Hope this helps,
    Nick
  6. Plump
    Plump
    Feb 22, 2002
    636
    19
    under the bridge
    One more
    Today it is easy to find (ebay or some second hand marketplace) old pronto for <50£
    If you have less than 10 units even 1MB remote is enough. There is noway around Pronto nowdays. And if you have TAG device you have to buy it anyway.
