G
Yes I feed all the 3 inputs 1/2/3 with 12VDC, so i have 3 triggers available at outputs 6/7/8. I tested the switches without power supply with a multimeter and the contact is ok between 1-6, 2-7 and 3-8 but when i put the power supply i have not 12V but 3V or 4V and after 2 minutes the power supply is very hot and then broken (0V output).Are you feeding the 12 vdc into ALL switches pins 1,2 and 3 and looking for an output on 8
you have three switches
inputs ---------- outputs
1 ------------ -- 6
2 ------------- 7
3 ------------- 8
Why not switch the gnd line input on Pin 1 and output on pin 6
I made a +12VDC rail, from which I branched three feeds to the A, B and C switches, via a 9-pin sub-D socket.
The + feed from the A switch is routed to the relay's coil, B is run to the "ON" subwoofer trigger, and C is run to the subwoofer's "Film" bias trigger.
I then ran a common direct ground feed to the relay's coil and one ea to the subwoofer's triggers.
If I recall correctly, you shouldn't feed any power at all to the action switches, I think they're just passive relays that can control a 12vdc power switch. So it's important that there's no current leakage from the 12vdc unit.
