Action camera questions
Discussion in 'General Tech & Gadget Forums' started by nopeda, Jan 24, 2018.
  1. nopeda
    nopeda
    Jan 24, 2018
    3
    GA, USA
    I want to get an action camera less expensive than a gopro and so far like the Dragon Touch Vision 3 4K for about $60 but on a Youtube they said it will only record for 10 minutes. They said all those type cameras are that way....they'll only record for 10 minutes at a time. You can record for 20 minutes but it will split it into 2 10 minute videos. Does that sound right, and if so is it true for all or most of those type cameras? How much recording time overall?
    I need to get it up and running as quickly as possible so do I need to order the memory card separately at the same time? Is it a micro SD like drones take or something else? Will it need an adapter to put it in a computer? What options of type of card are there?
    Any help or suggestions would be much appreciated
    David
