Acoustic Solutions
Discussion in 'Home Cinema Speakers' started by MurphmanL, Jul 16, 2004.
  1. MurphmanL
    MurphmanL
    Jul 16, 2004
    61
    Hertfordshire,UK
    +10
    Hey Guys,
    I am on a budget and so was looking at this home cinema setup from Acoustic Solutions from Argos.. I cant find any reviews or any specs for the satellites or woofer, just the total of 105w rms output.
    Does any 1 here have this system or know of a review of it?
    I am buying to replace my crappy 70W TCM Set which have just fooked it...
    Speakers
  2. sime
    sime
    Jul 7, 2004
    142
    +6
    hi murhmanl ive got some acoustics model 1033 i soppose they are ok if your really on a budget and maybe for your first set one thing wrong with them they r not dts or any other sound format than stereo and standard dolby digital 5.1 ive tried playing a dts support disc through them but no joy
  3. MurphmanL
    MurphmanL
    Jul 16, 2004
    61
    Hertfordshire,UK
    +10
    I think these are more advanced than your model
    These have a DTS Decoder as well as Optical and Coaxial connections,
    Im just having hard times finding things about em
  4. sime
    sime
    Jul 7, 2004
    142
    +6
    have you tried there website also check the price out for mission m7s 5.1 package you might be able to pick this up for around £150 :rolleyes:
  5. rozzar
    rozzar
    Sep 29, 2002
    1,056
    41
    Braintree
    +23
    i think your best route is to find a discontinued Sony/Panasonic/JVC/Pioneer model from the clearance racks of the likes of Dixons, Currys or even EmpireDirect.co.uk or qed-uk.com .They will outperform the Acoustics Solutions set, will last longer, give you the likes of SACD/DVD-Audio, ProLogic II and have enough power to drive higher quality speakers in the future.
  6. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
