Acoustic Solutions: Sound but no Picture via HDMI
Discussion in 'LCD & LED LCD TVs Forum' started by rzz, Feb 10, 2009.
Tags:
  1. rzz
    rzz
    Having a problem with my Acoustic Solutions TV in that when connecting via HDMI (either V+ or PS3) I get sound but no image... this has just started to happen.
    I have tried 2 HDMI cables (Which are successful in connecting V+ and my PS3 to my other HDTV) - but via the Acoustic Solution TV there is no picture.
    I have selected the HDMI output option on the TV and made sure that the cables were in as tight as possible.
    Is it likely that this TV has a fault with its HDMI port, given the above scenario?
    Has anyone else come across this problem?
    TV model is LCDW2295F.
    Just to confirm, the TV does work via scart as we have a standard Virgin box upstairs and the TV does pick up an image and sound through that... so either the HDMI port is 'poorly' or something needs resetting??
    All help appreciated.
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    does it work when you select hdmi, you get your problem, then go into the menu again, and select hdmi for the second time?
  3. rzz
    rzz
    I tried re-selecting HDMI and nothing worked - just TV sound... no PS3 sound though which is strange.
    Called Argos and they are taking it in to be fixed.... for what its worth!
