Acoustic Solutions DS 833 - muffled sound
Discussion in 'AV Receivers & Amplifiers' started by terryeden, Mar 31, 2005.
  1. terryeden
    terryeden
    Mar 30, 2005
    315
    Oxford
    +18
    I've got an Acoustic Solutions DS 833 ( http://www.acousticsolutions.net/product.asp?ID=181 )
    which has developed an odd little problem.
    Both the front right and the surround right speakers sound muffled. I don't mean "not using £squillion titanium plated cable" muffled, I mean "like they're under a pillow" muffled.
    I've swapped the speakers and wires around, and it seems to be the output from the amp that's the problem.
    Is it likely that there's some corrosion inside the terminators - or some other problem? Could the DSP be having a senior moment?
    Or, hopefully, am I overlooking something obvious?
    Any suggestions gratefully received!
    Terry
