Acoustic Solutions 37" lcd in argos
Discussion in 'LCD & LED LCD TVs Forum' started by mrchimps, Sep 5, 2007.
Tags:
  1. mrchimps
    mrchimps
    Aug 28, 2007
    17
    I have just bought the 37" lcd tv from argos (LCD37805HD)
    so far im very pleased with it, but just wanted to check im getting the best out of it.
    i have set my sky+ box to rgb out and connected via scart, but cant see an rgb setting on the tv? Is it auto rgb on scart 1 or 2 or does it not do rgb?
    any help appreciated.
  2. DES-Lite
    DES-Lite
    Feb 4, 2006
    163
    16
    Belfast
    Assuming the setup isnt too different from the LCD32NK750HDF you may waana check if the box will output RGBs and select the scart 2-s although scart 2 is the main recording channel on mine i.e. you can send any connected signal out of it.... so if you also have say a pvr etc you may just wanna stick it on ext1 or ext3 if it does component signals.
