Acoustic Research MC.1 Holographic series
Discussion in 'Home Cinema Speakers' started by titanax, Apr 6, 2002.
  1. titanax
    titanax
    I don't really know much about center speakers, & how you should select one, so when I ended up with an AR Holographic imaging series mc.1 center speaker....well I am clueless !
    Should I keep it, or dump it ?!
  2. freak1942
    freak1942
    Feb 6, 2005
    3
    Hoofddorp
    The inventor of "holography" in audio is CARVER in USA.
    His unit, CARVER C-9 Sonic Holography Generator , look Ebay.
    Read your manual, when no better stereo or when the spatial image is not improved, the MC.1 is not doing the job intended to be.
    I have the C-9 and is really improving stereo imaging, it requires a thorough placement of speaker before you get the sweet spot.
    The theory behind holography is very good and works well in normal stereo setup.
    It is not a unit with sonic tricks, it does not add something, but cancels delayed signals which directs to the wrong earside.
    In a normal 60/60/60 degrees setup you can hear signals coming from outside the LH and Rh boxes.
    I do not believe in Surround, it is like the BOSE speakers, its not stereo.
    ______________________________________
    AR-90’s refurbishing, REVOX tuner B760, REVOX amplifier B750 Mk ii, CARVER C-9 sonic holography generator, REVOY DVD player, DBX BoomBox (Sub Harmonic Synthesizer), QUADRAL Shogun Mk iv temporarily.
