Acoustic Energy Aego2 sub Q?
Discussion in 'Subwoofers' started by G1OSE, Feb 14, 2003.
  1. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    hi i have the Acoustic Energy Aego2 set up on my pc and wanted to no if the sub could be used in a home cinema set up on this website it shows connections but im a bit confused on one of them www.AEGO2.com
    it says you can connect to a home cinema but then you have to use 2 sets of speaker outs to then use the speakers connected to the sub but i just want to use the sub i no its not the best sub but it would work well for now in my soon to be set up
    cheers for the help!
  2. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    can anyone shed any light???????????????
  3. eddiea
    eddiea
    Looks like you can do it, have a look on your website link in "How to connect", "Upgrade Connections", it says you can use the centre phono.
  4. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    yes but does that mean you run a single phono from sub out into the centre in or what
    thats the bit i dont understand
    cheers for the help though
  5. eddiea
    eddiea
    Yes that's how I read it, why not give it a try.
  6. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    ok then cheers!:smashin:
  7. eddiea
    eddiea
    Let me know how it goes:smashin:
