Acoustic Energy AEGO P5
Discussion in 'Home Cinema Speakers' started by dann, Aug 25, 2003.
  1. dann
    dann
    Aug 25, 2003
    134
    Hi there, first post so be gentle with me, I have just got the Acoustic Energy AEGO P5 to replace my existing surround speakers, the trouble is my speaker wires are buried in the wall with spring clip terminal mounted on the wall, the aego p5's uses RCA type connection to the speakers, without having to chisel wall again, can I make up speaker cables with one end bare and the other with the RCA plug, if so can anyone tell me which would be the + and - ond the RCA plug,
    Thanks for your time
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Positive to the centre and negative to the outside
  3. dann
    dann
    Aug 25, 2003
    134
    ok
    thanks for your reply
  4. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No problems - that's what we're here for ;)
