Acoustic energy aego p5 vs. aego 5
Discussion in 'AV Receivers & Amplifiers' started by chrissles, Oct 2, 2003.
  1. chrissles
    chrissles
    Please help a very confused novice who wants to put a simple home cinema system together.
    I have a dvd recorder (Panasonic EMR50)which I believe has a DTS decoder. Therefore presumably I don't need the processor part of the aego 5 i.e. I could buy the aego 5 not the aego p5.
    However from what I've seen the P5 has a display and remote, which presumably allows you to set up the system easily and set speaker delays etc etc. The 5 does not have this, so is it possible to configure these on the 5?
    Am I wrong about this? How easy would the two systems be to set up, and how could I configure the delays in each case? help!!
