Acoustic Energy 309 Floorstanders - What AMP?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by cominatcha, May 10, 2005.
  1. cominatcha
    cominatcha
    Sep 21, 2004
    154
    +3
    Hi Everyone,
    Got my self some Acoustic Energy 309's thanks to avnutter.
    Now I love my Jazz, Soul, RnB some HipHop and some Nitin Sawnhey BUT what do I use to get some nice rich sound out of these ?
    So far I have only read posts on a NAD C352CT most being positive.
    My Budget is 200 - 300. Anyone got any suggestions ?
    These speakers have the capability of being Bi-Wired :rolleyes: Can anyone give me a quick tutorial into what that means :-D and would it make the sound better? If it will how will I do it ? what will I need.
    By the way my aim is to wire this up to my HTPC and play my cd's/mp3's through that!
    All much appreciated !! This is a great Forum
    Rox :thumbsup:
  2. cominatcha
    cominatcha
    Sep 21, 2004
    154
    +3
    I've done some more reading,
    Here is a list, does anyone have these amps (I'm sure someone has!!) - how do you find it for music ? Any thoughts ?
    cambridge audio azur 640a £249.95
    NAD C352CT £319.00
    Arcam A80 £600.00
    Now - there are 3 price ranges. Due to lack of money I will use a HTPC to play my MP3 music through one of these AMPS driving Acoustic Energy 309's.
    Come on - someone must have a opinion !! Even if its "your wasting your time" :) - well maybe not that !!
    Eventually I will marry them up to a nice CD player but that all depends on money!!
    Thanks in Advance
    :thumbsup:
  3. Kaldison
    Kaldison
    May 12, 2005
    156
    Bristol
    +43
    I have a pair of 309's and am using a Musical Fidelity X-80 amp which sounds fantastic!, original price was £600 but can now be found for about £250 apparently – definately worth checking out! Do a search for it on http://forum.hifichoice.co.uk/ (although seems to be down at the mo), lots of people have been raving about it on there over the last month or so.
    Paul
  4. cominatcha
    cominatcha
    Sep 21, 2004
    154
    +3
    I've done a GOOGLE search and hey presto the AMP you have suggested has come up for £250. I am going to look into this and the others I have mentioned and see what best fits me.
    Thanks paul.r will look into this. :)
    Anyone else got any thoughts? :thumbsup:
  5. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    i wouldn't put a £200 amp on £750 speakers. They are worthy of more. As someone suggested, that MF is a possibliity. I personaly would look into a secondhand Quad, Tag McLaren 60i, Exposure 3010 or something tbh. Should find something good for £300 ish
  6. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    incidentally biwiring means that the tweeter can get its own feed from the amp and the bass driver(s) can get their own feed. Thats why there are 4 terminals on the speakers. What I would do if i were you would be to get some good speaker cable and connect it to the high frequency (upper) terminals. Then replace the brass shorting links with another 2 inchs of the same speaker wire you used from the amp to the tweeter terminals. Gives you 90% of the sonic benefits of biwiring but as you only have one speaker cable run, allows you to afford better cable :D
    Try some Nordost Flatline Gold for a fast, tight, rhythmic sound or Black Rhodium AST200 for a smooth, warm sound.
